Why is one of my devices shown as "offline"?
criarrdelcar
criarrdelcar Posts: 4 ✭✭
edited January 2022 in General questions
One of my devices is shown as offline and I have tried many things to fix this. I have tried reinstall, as well as a full clean reinstall of the program (restarting after uninstall and then again after reinstall). That did not work and I have a another laptop with TeamViewer on it as well, and it works fine establishing connections to and from it. I can connect to other devices from this one, however, the option to connect to this one is simply greyed out and I can't connect *to* it.
I have a Lenovo Y920 running Windows 10 Pro 64-bit, and the program release is 15.25.8.
If anyone could help me I would seriously appreciate it!!!👍👍👍
  • ER1219
    ER1219 Posts: 1
    same issue, anyone please help...thanks
  • .Carol.fg.
    .Carol.fg. Posts: 1,083 Moderator
    Hi @ER1219 ,
    Welcome to our Community and thanks for bringing attention to this question!
    Please check if the partner device is turned on and with internet access.
    We also recommend using TeamViewer's newest version on both sides of the connection.
    Let us know how it goes, and if you need any further help. 🙋‍♀️
    Best, Carol
