Policy Assigment Not Working
SupportS2L
Posts: 4 ✭✭
Policy Assigment seems Not Working.
I assigned the policy to the group, but the devices are not "inheritaging".
In the management console, the "policy" column is empty for every devices.
When I assign a policy directly to the device from the device's properties, the property is not changed.
When use Assign Teamviewer policies button under Design & Deploy, it get stuck on "assigning policy".
Two months later, no answer from TV staff...
I found by myself how to correctly apply policy;
- The devices in the group don't inherit the policy if a policy is applied to the group after the devices has been added to the group: you need to change the policy to "inherit" on all devices
- Moving the devices to a new group with policy applied don't work either.
- Assign to many devices still get stuck on assigning policy with Internet Explorer, it works with Firefox ans Chrome but the javascript get frequently stucked.
The only reliable way I found is to use the API to force inherit on all devices in a group:
$token = "XXXXX"
$bearer = "Bearer",$token
$header.Add("authorization", $bearer)
# Récupérer l'ID du groupe [NAME]
$request = Invoke-RestMethod -Uri "https://webapi.teamviewer.com/api/v1/groups?name=GROUPNAME" -Method Get -Headers $header
$GroupID = $request.groups.id
# Récupérer tous les devices du groupe [NAME]
$request = Invoke-RestMethod -Uri "https://webapi.teamviewer.com/api/v1/devices?groupid=$GroupID" -Method Get -Headers $header
$data = @{
policy_id = "inherit";
$json = $data | ConvertTo-Json;
$contentType = "application/json"
ForEach($item in $request.devices)
# On passe en mode hériter
if($Item.policy_id -notlike "inherit"){
$Item.alias
$DeviceID = $Item.device_id
# Appliquer la stratégie
$request = Invoke-RestMethod -Uri "https://webapi.teamviewer.com/api/v1/devices/$DeviceID" -ContentType $contentType -Method Put -Headers $header -Body $Json
$x++
write-host $xI think that policy apply should be improved and the way it works well documented.
Hope this post will help.
3 -
It's 2023, policy assignment is still "buggy"
1
