Login issue
immanrio
immanrio Posts: 1
edited August 2023 in servicecamp support
Hi Forum,
I have machine connected to teamviewer which is used to run the bot. A pop up shows up each time when I logout from the team viewer which hampers the bot performance. Please suggest me a solution. I have attached the screenshot for ur reference.
  • .Carol.fg.
    .Carol.fg. Posts: 1,087 Moderator
    Hi @immanrio ,
    Thanks for your question and welcome to our Community!
    You can disable this message by following the steps below:
    On the Windows tray menu, right-click the TeamViewer icon and open TeamViewer Options
    Then click Advanced Show Advanced Options ➜ in the field Advanced settings for connections to this computer you will be able to configure new settings for Random password after each session.
    👉 The option Show Confirmation is the one that causes you to see the popup message after each session.
    I hope this helps! 🍀
    Let us know if we can help you any further!
    Best, Carol
