Navigation keys not working
I'm using using Teamviewer app on a Pixel 4a with Android 11 to control another Android phone (V8), using QuickSupport.
In the controlling teamviewer app the icons for the navigation keys (home, back, last apps) are shown, but pressing has no effect.
And help or ideas welcome, thanks !!
    Hello @remoteguru,
    Could you tell us what is the exact model of the Android device you are trying to connect to?
    Many thanks in advance.
    Stay safe and sane! ?
  • remoteguru
    Hello Jean,
    thanks you for your quick response!
    The phone I connect to is a Samsung A3 2017 (model number SM-A320FL), running Android 8.0.
    Stay safe and sane too !!
  • wolfung
    wolfung Posts: 1
    This is not only a problem with Samsung phones. I am having the same issue on a Motorola. this tells me it might not be about the phones.
