How to disable clipboard sync?
Trying to disable clipboard sync.  I've seen some old Internet postings talking about an Advanced setting to disable clipboard sync, but it doesn't appear to be there in newer versions. Any help would be appreciated.  FYI, I am using Ubuntu to connect to a Windows 10 client, if that matters.
- Scott
    Hello @sneader,
    I confirm that in the current version of TeamViewer for Linux, unfortunately, you cannot disable the clipboard sync.
    Best regards
  • cavdur
    cavdur Posts: 2 ✭✭
    Is the clipboard sync feature available in commercial linux teamviewer edition?
  • cavdur
    cavdur Posts: 2 ✭✭
    I checked the ubuntu teamviewer 15.47.3 edition whether to disable/enable clipboard sync is available. But it is not available yet. When is " disable the clipboard sync feature" going to be available?
