Why the Automatic recording no longer works?
Okolicanyi
Okolicanyi Posts: 2
edited November 2023 in General questions
Is it something wrong on my end?
Is it because I'm not using the "terrible" new interface?
It was working until 22/11/2023.
I did not change anything.
Start recording of remote control sessions automatically is selected.
I have free space on disk.
The recording directory is also setup.
If I click to start recording during the session manually - it works fine and it's able to save in there with no problem...
Please advise.
    JeanK Posts: 7,056 Community Manager 🌍
    edited November 2023 Answer ✓
    @Okolicanyi In my case, it worked as expected. The recording started automatically.
    Perhaps a full uninstallation would do the job?
    We explain how to uninstall TeamViewer completely from your devices here: Uninstall TeamViewer on Windows.
    /JeanK
    Hi @Okolicanyi,
    Great to see you posting for the first time! 🚀
    I'm about to try to reproduce the issue on my test device.
    I'll keep you posted about the results!
    /JeanK
    /JeanK
  • Yeah, you were right, maybe it was something in the registry.
    After full reinstallation it works again.
    Thanks.
    I'm glad the full reinstallation could fix the issue.
    Have a great day and happy connecting! 🙂
    /JeanK
  • Auto recording of session is not working . I have verified that the settings is turn on but still does not auto record. recording light and Timmer is on but no file is generated. Stopping recording to save does not work. manually starting recording also does not generate a file. This started after Nov 27th ?
    Hi @Wizardben,
    Thank you for your post!
    Have you tried to reinstall TeamViewer on both sides of the connection, as suggested above?
    It fixed the issue for Okolicanyi.
    /JeanK
  • removing it from the registry keys was the solution to restoring the record feature.
    Thank you, @Wizardben, for letting us know!
    Have a great day!
    /JeanK
  • GarryG
    GarryG Posts: 1
    Having the same problem - but looking the new GUI description, the automatic recording is only listed under the outgoing connections - I want to record sessions that are done connecting TO this PC … can this be configured?
  • TVSupportMatt
    TVSupportMatt Posts: 95 Staff member 🤠
    Hello @GarryG
    Unfortunately, it is currently only possible to record outgoing sessions. This topic is covered in detail via the Knowledge Base article pasted below.
    Record a remote session (teamviewer.com)
    We do appreciate your comment as we value all feedback. Have a great day!
