HOW DO I TURN OFF THE SURVEY?
How do I stop getting the survey at the end of a remote session. THIS IS REALLY annoying becasue it doe snot close by itself it just sits ther I have a lot ao fsession through out the day and I don't want to keep closing this box.
I disengaged this by unchecking "Show Comment Window After Each Session" in the management console, under User Management. You might have to do this for every user. Hope that helps!
Hi rsgooch,
Thanks for posting!
ZachatCDMS is right in that you can turn it off in the managment console.
This is a feature of the software, the comments go into your connection reports for future reference.
You can also turn this option off by clicking your profile name in the software > Edit Profile > Uncheck the bottom box "Show Comments window after each Session"
-Scotty
Senior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?1
