Can i install Team Viewer in my user laptop
Hi, example : i have corporate license  buy under company name "A" and i install  it in few PC at our sub company name "B" to support user there. Is it violate the Team Viewer Policy?
  • Scotty
    Hi nur_atia,
    This is not a problem at all.
    Our software has limitations on each license, for instance the corporate license has 3 concurrent users. So you can use these 3 concurrent users however you like.
    Happy TeamViewer-ing!
    -Scotty
    Senior Moderator
  • nur_atia
    Hi Scotty,
    Ok, then for the company "B",  during the installation.. should it tick for "personal use" or "commercial use". Company "A" and "B" are different company name.
  • Scotty
    Hi nur_atia,
    This would still be for "Commercial Use"
    Personal use is only applicable if the software is installed by a personal user and they will not be using it for any commercial use.
    -Scotty
    Senior Moderator
