Can’t connect to partner computer when using an iPad
Cymbria
Cymbria Posts: 3 ✭✭
edited January 22 in Mobile
I can’t connect to partner computer when using my iPad because it won’t bring up a keypad so I can enter my PIN number. It used to work fine. Any help appreciated. Thanks!
  • Ying_Q
    Ying_Q Posts: 2,609 Moderator
    Hello @Cymbria,
    Thank you for joining the Community!
    Have you tried to press on the toolbar in the bottom right corner and select the Keyboard during the connection?
    I have highlighted the Keyboard option in the same screenshot. Once you choose the Keyboard, the full keyboard should then display on your iPad screen for you to enter the PIN.
    Hope it works for you with the keyboard on display this time.
    Community Moderator/中文社区管理员
  • Cymbria
    Cymbria Posts: 3 ✭✭
    Thanks for your response. I tried that but just get a bar along the bottom. It used to work great, but hasn’t for approx. 1 year.
  • Ying_Q
    Hello @Cymbria,
    Thank you for coming back to me with the screenshot.
    I have tried today to run a test connection from both iPhone and iPad to a Windows device. The connection went smoothly and the keyboard option was also available.
    May I ask you to update TeamViewer to the latest version on both devices and then try again for the connection?
    At the same time, can you share the device operating system with us please?
    Keep me posted about how you go with the connection!
  • Cymbria
    Cymbria Posts: 3 ✭✭
    Trying to connect from an iPad with IOS 17.2 to a laptop with Windows 11 Home. Thanks
