Change from Business to personal.
marlin87
I accidentally install the business version. Even in i unistall the program it wont allow me to reinstall. Please advise.
Hello marlin87,
Did you try deleting your settings when you uninstalled the teamviewer? If not here is how you can do that,
1. You go to uninstal the teamviewer. 2. You check the box that says delete settings. 3. Then you delete and reïnstall the teamviewer .
I hope this helps
Iain Wels,
ICT-Support
If you found this helpfull please verify it as an solution, so it could help other people0 -
i did and it's still doesn't work .
Hello marlin87,
I don't think i can help you any further with this... I think you need to go to an moderator
Here is an link that maybe can help solve your problem!
https://community.teamviewer.com/t5/Knowledge-Base/Why-do-I-see-TeamViewer-trial-Your-trial-period-has-expired/ta-p/5267With kind regards, Met vriendelijke groet,
Iain Wels,
ICT-Support
