Hi, May I know where can I download the teamviewer v12.0.224043 for MacOS. I tried search from the download page, it only able download v12.0.25 latest
Hi @cchan9213,
Thank you for posting in the TeamViewer Community!
You may find the TeamViewer v12 download available on the TeamViewer homepage - https://www.teamviewer.com/en/download/previous-versions/previous-version-12x/. If there is a specific version of TeamViewer version you prefer based on your use case, kindly contact the TeamViewer Support Team for the option on TeamViewer downloads.
@Ebecpc We appreciate the help and support you share in the TeamViewer Community! We also encourage all users to download and use the latest supported TeamViewer version from the TeamViewer official site. Thank you for being so understanding!
Wish you both a great week!
No Problem glad i could,
as i had the seem problem in the past myself :)
Hi @Ebecpc ,
I able to download the version i needed. Appreciate for helping.
Hi @Ying_Q ,
Appreciate for helping too.
off course i would do normally do that if the version were in fact listed,
which it is not on the TeamViewer website
as i looked before i posted my 2 posts,
plus, the wayback machine link it in fact TeamViewer website but just a back-up page
regards
[removed per Community Guidelines - never download TeamViewer from third party sources]
hope those help you out
