team viewer does not open on debian 8
Hi! team viewer does not open on debian 8.
Here is some logs:fixme:service:scmdatabase_autostart_services Auto-start service L"MountMgr" failed to start: 2
fixme:service:scmdatabase_autostart_services Auto-start service L"PlugPlay" failed to start: 2
fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
fixme:ole:CoInitializeSecurity ((nil),-1,(nil),(nil),0,3,(nil),0,(nil)) - stub!
fixme:heap:HeapSetInformation (nil) 1 (nil) 0
fixme:process:SetProcessDEPPolicy (3): stub
fixme:msg:ChangeWindowMessageFilter 233 00000001
fixme:msg:ChangeWindowMessageFilter 4a 00000001
fixme:msg:ChangeWindowMessageFilter 407 00000001
fixme:msg:ChangeWindowMessageFilter 49 00000001
fixme:ver:GetCurrentPackageId (0x1aee9f8 (nil)): stub
fixme:ver:GetCurrentPackageId (0x1bee9f8 (nil)): stub
fixme:process:SetProcessShutdownParameters (00000100, 00000000): partial stub.
fixme:win:EnumDisplayDevicesW ((null),0,0x32d98c,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",0,0x32dcd4,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x32d98c,0x00000000), stub!
wine: Unhandled exception 0x40000015 in thread 9 at address 0x320023:0x00edf4ef (thread 0009), starting debugger...
err:seh:start_debugger Couldn't start debugger ("winedbg --auto 8 252") (2)
Read the Wine Developers Guide on how to set up winedbg or another debugger
  • NW-IT
    NW-IT Posts: 8
    It works here on Debian 8. I think you'll need to supply some more information ... ;)
    - How did you install TV?
    - How do you start it? (Manually from the menu? Automatically with the computer?)
    - Which desktop environment? (xfce, Gnome, ... ?)
    - Has it ever worked, or is this following an update/upgrade?
  • Here you go:
    - #dpkg -i <deb package name downloaded from TV website>
    - tried Both from menu and terminal
    - LXDE
    - it did on the older version and started ONCE after the package upgrade.
  • NW-IT
    NW-IT Posts: 8
    Sorry, I don't come by very often.
    If you start teamviewer from a terminal, what do you see? For example, this is what I see for a successful Teamviewer start:
    $ teamviewer
    Init...
    CheckCPU: SSE2 support: yes
    XRandRWait: No value set. Using default.
    XRandRWait: Started by user.
    Checking setup...
    Launching TeamViewer ...
    Launching TeamViewer GUI ...
  • Hi! It's literally the same thing.
    Checking setup...
    And then - nothing at all.
    It simple drops me back in xterm.
    in internal TV wine log there is some interesting messages:
    fixme:ver:GetCurrentPackageId (0x32f6d8 (nil)): stub
    fixme:win:EnumDisplayDevicesW ((null),0,0x32d538,0x00000000), stub!
    fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",0,0x32d880,0x00000000), stub!
    fixme:win:EnumDisplayDevicesW ((null),1,0x32d538,0x00000000), stub!
    wine: Unhandled exception 0x40000015 in thread 9 at address 0x7e6b0023:0x00ea0338 (thread 0009), starting debugger...
    err:seh:start_debugger Couldn't start debugger ("winedbg --auto 8 212") (2)
  • I'm having the same problem on Linux Mint 18, it was working then simply stopped.  Tried to purge and also tried upgrading to TeamViewer 12 with same issue.  Tried your solution, but I received and error on first dpkg command.  Reinstalled from downloaded Deb backage from teamviewer site and whoala! it works!  Thanks!  must have been the
    sudo find . -name *teamviewer* -exec rm -rf {} \;
    that made the difference!  Thanks for the assist, I was super frustrated!
  • Hi, purging all of TV files and reinstall worked GREAT, thanks for your assistance.
  • rok
    rok Posts: 22 ✭✭
    I have the same issue in Ubuntu 16.04.. I already tried sevel times to clean up the system and reinstall, it works for some days, then the problem is back.. can anyone help me?
  • ChristianCay
    ChristianCay Posts: 184 Staff
    Dear rok,
    What version will you like to use full version or host?
    We are looking forward to your comments.
    Christian
  • I am using Linux Mint 18
  • rok
    rok Posts: 22 ✭✭
    I solved in this way, looking at /home/user/.config/teamviewer/client.conf the parameter [strng] FT_Start_Directories = "" was ridiculously long and I simply deleted anything between the " " as many of the directories were not even in my computer. Now Teamviewer is back!
    Anyway this always happens after some file transfers (with other ubuntu machines), then I clean that parameter and teamviewer comes back...
    I use Teamviewer 12.0.71.510 , licensed, full version.
  • I get this messag, but the application never starts...
  • DanielStm
    DanielStm Posts: 224 Staff
    Are you talking about TeamViewer 12?
    Then: Which message do you get. Explain in more detail.
    Or even better: Try TeamViewer 13
    Are you talking about TeamViewer 13?
    Then: Please open a new thread, include TV13 in the title.
    This thread is about TeamViewer 12.
    Linux Developer
Howdy, Stranger!
