update group
hello to everyone,
I would like to know
if there is a probability to update specific groups from the tv management console
(from tv12 to tv13)
:smileyhappy:
Julia Posts: 292 Staff
Hi geo_nass,
The best solution here would be to work with policies. You can create a TeamViewer policy in the Management Console with the option "Install new versions automatically" - after choosing it, click on edit and activate "All updates (includes new major versions)"
You can now assign the policy to the devices which you want to have on TeamViewer 13
Cheers,
Julia
Find this helpful? Say thanks by clicking on the Thumbs Up button.5
