Re: Update available!
beast-usa
beast-usa Posts: 80 ✭✭
@Esther
I just upgraded to the 13 version subscription :) so far working perfectly. You guys should consider letting people do it monthly? Paying all 12 months at once is going to be a little hard for some people just getting started.
Thank you for the GREAT SOFTWARE couldn't live without it!
  • Esther
    Hi @beast-usa
    That´s a valid point! I will forward your suggestion internally.
    And: Thank you for your feedback. We are happy to hear that you like TeamViewer 13! I am curious to hear: Which feature do you like most? Well, maybe this is worth to open a new thread ;-)
    All the best, Esther
  • Dan_D
    Dan_D Posts: 1
    I would like to support this.  Most large organisations are happier these days with Opex rather than Capex.  If you charged monthly for a subscription, then it makes it very easy for a large business to consume.
    In my case, the Capex procedure to authorise the yearly commitment for a subscription is simply too cumbersome and as a result we are considering other products.  I'd certainly further consider your product if you were to change the subscription model to charge monthly instead.
