Can sound from Android be played on my computer?
I know that I can play the sounds from another computer on my computer via TeamViewer.
I have got TeamViewer QuickSupport installed on my Android phone. Can the same be done here, that is, can I hear sound from Android on my computer? And can I do the vice-versa also? If yes, how?
1
Hi mousourik,
Thanks for your post!
At the moment, unfortunately audio can only be captured from Windows OS.
Other OS such as MacOS and Android are currently in as feature requests but are not features at the moment.
-Scotty
Senior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?8
thank u.
solved1 -
are there any news about the issue?
BR
gockel
