Windows 10 Insider Preview 15002 TeamViewer issues
tty0746
tty0746 Posts: 1
After installing build 15002, the TeamViewer client causes BSOD's. So far, the BSOD is caused by checking for updates and attempting to enter options.
  • elbea64
    elbea64 Posts: 70 ✭✭
    Insider Preview 15002 has a lot of terrible issues, i reverted back to 14986.
    The really good thing about windows 10 is that all the cheap jokes about win 95 will work again.
    Customer: Hello, i have windows 10
    MS-Support: Hello, how can i help you
    Customer: I have a problem
    MS-Support: You said that already
    »We are all born unique, but most of us will die as a copy.«
  • lda74
    lda74 Posts: 2 ✭✭
    I used the build 15002 intensively for 32 hours so far and the only problem I've received is the BSOD Teamviewer 12 ...
    No more issues
  • coppolino
    coppolino Posts: 1
    Ho risolto parzialmente mediante l'uso dell'app Teamviewer: telecomando. Con tale app non ho riscontrato nesun problema, l'unico inconveniente è non è possibile utilizzare funzioni venire chat o video :'(Cattura.PNG
  • dagger
    dagger Posts: 3 ✭✭
    I have no problem connecting with my other computers, or creating and connecting to a meeting. The only time that my computer crashes is when I do a screen share.
    I am able to use other applications to screen share no problem.
  • lda74
    lda74 Posts: 2 ✭✭
    updating to Insider preview 15007, I resolve all the BSOD too!!
  • dagger
    dagger Posts: 3 ✭✭
    Thanks, I am updating to 15007 now, and will confirm
  • dagger
    dagger Posts: 3 ✭✭
    I updated to Preview 15007 and I can now screen share.
    Thanks for the help
