Use TV to view screen of videogame
Good morning, TV use to monitor my pc from the phone Android. I use it often to make login in the video game even when they are not physically at home. The problem is that once, when the game started I saw it from the phone screen and could perform any operation. But now I still see only the desktop even though the game is running.how should I do to see the game screen as before?
  • Scotty
    Hi Supercao,
    Thanks for posting!
    Please note that TeamViewer is primarily business software and so is not optimised for gaming. However, can you try going to Extras > Options > Advanced > Advanced settings for connections to this computer > Check "ignore alpha blending". This will get rid of any "Glass" effects, but may fix the display issue.
    I hope this helps!
    -Scotty
    Senior Moderator
