Installation of TeamViewer 13 on OpenSUSE LEAP 42.3 does not work as expected
Installation of TeamViewer 13 on OpenSUSE LEAP 42.3 does not work as expected.
Coul'd you pls. provide a solution for the missing dependency? Is there an other Qt5 package to be installed?
bigblackbook:/home/.../TeamViewer # id
uid=0(root) gid=0(root) groups=0(root),33(video)
bigblackbook:/home/.../TeamViewer # rpm -i teamviewer_13.0.6634.x86_64.rpm
warning: teamviewer_13.0.6634.x86_64.rpm: Header V4 RSA/SHA1 Signature, key ID 0c1289c0: NOKEY
error: Failed dependencies:
/usr/lib64/qt5/qml/QtGraphicalEffects/qmldir is needed by teamviewer-13.0.6634-0.x86_64
/usr/lib64/qt5/qml/QtQuick/Controls/qmldir is needed by teamviewer-13.0.6634-0.x86_64
bigblackbook:/home/.../TeamViewer # find /usr/lib64/qt5/qml -type f -name "*qmldir*" -ls
1568428 4 -rw-r--r-- 1 root root 124 Sep 12 2016 /usr/lib64/qt5/qml/Qt/labs/folderlistmodel/qmldir
1568431 4 -rw-r--r-- 1 root root 103 Sep 12 2016 /usr/lib64/qt5/qml/Qt/labs/settings/qmldir
1568434 4 -rw-r--r-- 1 root root 86 Sep 12 2016 /usr/lib64/qt5/qml/QtQml/Models.2/qmldir
1568437 4 -rw-r--r-- 1 root root 111 Sep 12 2016 /usr/lib64/qt5/qml/QtQml/StateMachine/qmldir
1568439 4 -rw-r--r-- 1 root root 39 Sep 12 2016 /usr/lib64/qt5/qml/QtQml/qmldir
1568445 4 -rw-r--r-- 1 root root 116 Sep 12 2016 /usr/lib64/qt5/qml/QtQuick/LocalStorage/qmldir
1568448 4 -rw-r--r-- 1 root root 108 Sep 12 2016 /usr/lib64/qt5/qml/QtQuick/Particles.2/qmldir
1568451 4 -rw-r--r-- 1 root root 117 Sep 12 2016 /usr/lib64/qt5/qml/QtQuick/Window.2/qmldir
1568454 4 -rw-r--r-- 1 root root 133 Sep 12 2016 /usr/lib64/qt5/qml/QtQuick/XmlListModel/qmldir
1568442 4 -rw-r--r-- 1 root root 106 Sep 12 2016 /usr/lib64/qt5/qml/QtQuick.2/qmldir
1569936 4 -rw-r--r-- 1 root root 49 Mar 4 2017 /usr/lib64/qt5/qml/org/kde/solid/qmldir
1654007 4 -rw-r--r-- 1 root root 49 Dec 20 2016 /usr/lib64/qt5/qml/org/kde/games/core/qmldir
1569751 4 -rw-r--r-- 1 root root 107 Sep 12 2016 /usr/lib64/qt5/qml/QtSensors/qmldir
1569766 4 -rw-r--r-- 1 root root 119 Sep 12 2016 /usr/lib64/qt5/qml/QtPositioning/qmldir
1570545 4 -rw-r--r-- 1 root root 104 Jul 21 2016 /usr/lib64/qt5/qml/QtWebChannel/qmldir
1573111 4 -rw-r--r-- 1 root root 64 Sep 9 2016 /usr/lib64/qt5/qml/QtWebKit/experimental/qmldir
1573114 4 -rw-r--r-- 1 root root 92 Sep 9 2016 /usr/lib64/qt5/qml/QtWebKit/qmldir
bigblackbook:/home/.../TeamViewer # cat /etc/os-release
NAME="openSUSE Leap"
VERSION="42.3"
ID=opensuse
ID_LIKE="suse"
VERSION_ID="42.3"
PRETTY_NAME="openSUSE Leap 42.3"
ANSI_COLOR="0;32"
CPE_NAME="cpe:/o:opensuse:leap:42.3"
BUG_REPORT_URL="https://bugs.opensuse.org"
HOME_URL="https://www.opensuse.org/"
bigblackbook:/home/.../TeamViewer # uname -a
Linux bigblackbook.suse 4.4.104-39-default #1 SMP Thu Jan 4 08:11:03 UTC 2018 (7db1912) x86_64 x86_64 x86_64 GNU/Linux
bigblackbook:/home/.../TeamViewer # yum info libQt5Core5
Installed Packages
Arch : x86_64
Version : 5.6.2
Release : 6.1
Repo : installed
Summary : Qt 5 Core Library
URL : http://qt.digia.com
License : GPL-3.0 or SUSE-LGPL-2.1-with-digia-exception-1.1
Description : The Qt 5 Core library.
bigblackbook:/home/.../TeamViewer # yum whatprovides '*/qmldir'
libQt5Positioning5-5.6.2-1.4.x86_64 : Qt 5 Positioning Addon
Repo        : installed
Matched from:
Filename    : /usr/lib64/qt5/qml/QtPositioning/qmldir
libQt5Sensors5-imports-5.6.2-1.4.x86_64 : Qt 5 Serial Port Addon - QML imports
Repo        : installed
Matched from:
Filename    : /usr/lib64/qt5/qml/QtSensors/qmldir
libQt5WebChannel5-imports-5.6.2-1.3.x86_64 : Qt 5 WebSockets Library - QML imports
Repo        : installed
Matched from:
Filename    : /usr/lib64/qt5/qml/QtWebChannel/qmldir
libQt5WebKit5-imports-5.6.2-1.26.x86_64 : Qt5 WebKit Library - QML imports
Repo        : installed
Matched from:
Filename    : /usr/lib64/qt5/qml/QtWebKit/experimental/qmldir
Filename    : /usr/lib64/qt5/qml/QtWebKit/qmldir
libQtQuick5-5.6.2-2.3.x86_64 : Qt 5 Declarative Library
Repo        : installed
Matched from:
Filename    : /usr/lib64/qt5/qml/QtQml/qmldir
Filename    : /usr/lib64/qt5/qml/QtQml/Models.2/qmldir
Filename    : /usr/lib64/qt5/qml/QtQuick.2/qmldir
Filename    : /usr/lib64/qt5/qml/QtQuick/LocalStorage/qmldir
Filename    : /usr/lib64/qt5/qml/Qt/labs/settings/qmldir
Filename    : /usr/lib64/qt5/qml/Qt/labs/folderlistmodel/qmldir
Filename    : /usr/lib64/qt5/qml/QtQml/StateMachine/qmldir
Filename    : /usr/lib64/qt5/qml/QtQuick/XmlListModel/qmldir
Filename    : /usr/lib64/qt5/qml/QtQuick/Window.2/qmldir
Filename    : /usr/lib64/qt5/qml/QtQuick/Particles.2/qmldir
libQtWebKit4-4.8.7+2.3.4-6.24.x86_64 : Open source Web Browser engine based on Qt4
Repo        : installed
Matched from:
Filename    : /usr/lib64/qt4/plugins/imports/QtWebKit/qmldir
libkf5kdegames6-17.04.2-1.1.x86_64 : Library for KDE Games
Repo        : installed
Matched from:
Filename    : /usr/lib64/qt5/qml/org/kde/games/core/qmldir
libqt4-x11-4.8.6-16.6.x86_64 : Qt 4 GUI related libraries
Repo        : installed
Matched from:
Filename    : /usr/lib64/qt4/plugins/imports/Qt/labs/shaders/qmldir
Filename    : /usr/lib64/qt4/plugins/imports/Qt/labs/gestures/qmldir
Filename    : /usr/lib64/qt4/plugins/imports/Qt/labs/particles/qmldir
Filename    : /usr/lib64/qt4/plugins/imports/Qt/labs/folderlistmodel/qmldir
solid-imports-5.32.0-1.3.x86_64 : KDE Desktop hardware abstraction
Repo        : installed
Matched from:
Filename    : /usr/lib64/qt5/qml/org/kde/solid/qmldir
