Installation of TeamViewer 13 on OpenSUSE LEAP 42.3 does not work as expected
Árpád
in Linux only
Installation of TeamViewer 13 on OpenSUSE LEAP 42.3 does not work as expected.
Coul'd you pls. provide a solution for the missing dependency? Is there an other Qt5 package to be installed?
bigblackbook:/home/.../TeamViewer # id
uid=0(root) gid=0(root) groups=0(root),33(video)
bigblackbook:/home/.../TeamViewer # rpm -i teamviewer_13.0.6634.x86_64.rpm
warning: teamviewer_13.0.6634.x86_64.rpm: Header V4 RSA/SHA1 Signature, key ID 0c1289c0: NOKEY
error: Failed dependencies:
/usr/lib64/qt5/qml/QtGraphicalEffects/qmldir is needed by teamviewer-13.0.6634-0.x86_64
/usr/lib64/qt5/qml/QtQuick/Controls/qmldir is needed by teamviewer-13.0.6634-0.x86_64
bigblackbook:/home/.../TeamViewer # find /usr/lib64/qt5/qml -type f -name "*qmldir*" -ls
1568428 4 -rw-r--r-- 1 root root 124 Sep 12 2016 /usr/lib64/qt5/qml/Qt/labs/folderlistmodel/qmldir
1568431 4 -rw-r--r-- 1 root root 103 Sep 12 2016 /usr/lib64/qt5/qml/Qt/labs/settings/qmldir
1568434 4 -rw-r--r-- 1 root root 86 Sep 12 2016 /usr/lib64/qt5/qml/QtQml/Models.2/qmldir
1568437 4 -rw-r--r-- 1 root root 111 Sep 12 2016 /usr/lib64/qt5/qml/QtQml/StateMachine/qmldir
1568439 4 -rw-r--r-- 1 root root 39 Sep 12 2016 /usr/lib64/qt5/qml/QtQml/qmldir
1568445 4 -rw-r--r-- 1 root root 116 Sep 12 2016 /usr/lib64/qt5/qml/QtQuick/LocalStorage/qmldir
1568448 4 -rw-r--r-- 1 root root 108 Sep 12 2016 /usr/lib64/qt5/qml/QtQuick/Particles.2/qmldir
1568451 4 -rw-r--r-- 1 root root 117 Sep 12 2016 /usr/lib64/qt5/qml/QtQuick/Window.2/qmldir
1568454 4 -rw-r--r-- 1 root root 133 Sep 12 2016 /usr/lib64/qt5/qml/QtQuick/XmlListModel/qmldir
1568442 4 -rw-r--r-- 1 root root 106 Sep 12 2016 /usr/lib64/qt5/qml/QtQuick.2/qmldir
1569936 4 -rw-r--r-- 1 root root 49 Mar 4 2017 /usr/lib64/qt5/qml/org/kde/solid/qmldir
1654007 4 -rw-r--r-- 1 root root 49 Dec 20 2016 /usr/lib64/qt5/qml/org/kde/games/core/qmldir
1569751 4 -rw-r--r-- 1 root root 107 Sep 12 2016 /usr/lib64/qt5/qml/QtSensors/qmldir
1569766 4 -rw-r--r-- 1 root root 119 Sep 12 2016 /usr/lib64/qt5/qml/QtPositioning/qmldir
1570545 4 -rw-r--r-- 1 root root 104 Jul 21 2016 /usr/lib64/qt5/qml/QtWebChannel/qmldir
1573111 4 -rw-r--r-- 1 root root 64 Sep 9 2016 /usr/lib64/qt5/qml/QtWebKit/experimental/qmldir
1573114 4 -rw-r--r-- 1 root root 92 Sep 9 2016 /usr/lib64/qt5/qml/QtWebKit/qmldir
bigblackbook:/home/.../TeamViewer # cat /etc/os-release
NAME="openSUSE Leap"
VERSION="42.3"
ID=opensuse
ID_LIKE="suse"
VERSION_ID="42.3"
PRETTY_NAME="openSUSE Leap 42.3"
ANSI_COLOR="0;32"
CPE_NAME="cpe:/o:opensuse:leap:42.3"
BUG_REPORT_URL="https://bugs.opensuse.org"
HOME_URL="https://www.opensuse.org/"
bigblackbook:/home/.../TeamViewer # uname -a
Linux bigblackbook.suse 4.4.104-39-default #1 SMP Thu Jan 4 08:11:03 UTC 2018 (7db1912) x86_64 x86_64 x86_64 GNU/Linux
bigblackbook:/home/.../TeamViewer # yum info libQt5Core5
Installed Packages
Arch : x86_64
Version : 5.6.2
Release : 6.1
Repo : installed
Summary : Qt 5 Core Library
URL : http://qt.digia.com
License : GPL-3.0 or SUSE-LGPL-2.1-with-digia-exception-1.1
Description : The Qt 5 Core library.
bigblackbook:/home/.../TeamViewer # yum whatprovides '*/qmldir'
libQt5Positioning5-5.6.2-1.4.x86_64 : Qt 5 Positioning Addon
Repo : installed
Matched from:
Filename : /usr/lib64/qt5/qml/QtPositioning/qmldir
libQt5Sensors5-imports-5.6.2-1.4.x86_64 : Qt 5 Serial Port Addon - QML imports
Repo : installed
Matched from:
Filename : /usr/lib64/qt5/qml/QtSensors/qmldir
libQt5WebChannel5-imports-5.6.2-1.3.x86_64 : Qt 5 WebSockets Library - QML imports
Repo : installed
Matched from:
Filename : /usr/lib64/qt5/qml/QtWebChannel/qmldir
libQt5WebKit5-imports-5.6.2-1.26.x86_64 : Qt5 WebKit Library - QML imports
Repo : installed
Matched from:
Filename : /usr/lib64/qt5/qml/QtWebKit/experimental/qmldir
Filename : /usr/lib64/qt5/qml/QtWebKit/qmldir
libQtQuick5-5.6.2-2.3.x86_64 : Qt 5 Declarative Library
Repo : installed
Matched from:
Filename : /usr/lib64/qt5/qml/QtQml/qmldir
Filename : /usr/lib64/qt5/qml/QtQml/Models.2/qmldir
Filename : /usr/lib64/qt5/qml/QtQuick.2/qmldir
Filename : /usr/lib64/qt5/qml/QtQuick/LocalStorage/qmldir
Filename : /usr/lib64/qt5/qml/Qt/labs/settings/qmldir
Filename : /usr/lib64/qt5/qml/Qt/labs/folderlistmodel/qmldir
Filename : /usr/lib64/qt5/qml/QtQml/StateMachine/qmldir
Filename : /usr/lib64/qt5/qml/QtQuick/XmlListModel/qmldir
Filename : /usr/lib64/qt5/qml/QtQuick/Window.2/qmldir
Filename : /usr/lib64/qt5/qml/QtQuick/Particles.2/qmldir
libQtWebKit4-4.8.7+2.3.4-6.24.x86_64 : Open source Web Browser engine based on Qt4
Repo : installed
Matched from:
Filename : /usr/lib64/qt4/plugins/imports/QtWebKit/qmldir
libkf5kdegames6-17.04.2-1.1.x86_64 : Library for KDE Games
Repo : installed
Matched from:
Filename : /usr/lib64/qt5/qml/org/kde/games/core/qmldir
libqt4-x11-4.8.6-16.6.x86_64 : Qt 4 GUI related libraries
Repo : installed
Matched from:
Filename : /usr/lib64/qt4/plugins/imports/Qt/labs/shaders/qmldir
Filename : /usr/lib64/qt4/plugins/imports/Qt/labs/gestures/qmldir
Filename : /usr/lib64/qt4/plugins/imports/Qt/labs/particles/qmldir
Filename : /usr/lib64/qt4/plugins/imports/Qt/labs/folderlistmodel/qmldir
solid-imports-5.32.0-1.3.x86_64 : KDE Desktop hardware abstraction
Repo : installed
Matched from:
Filename : /usr/lib64/qt5/qml/org/kde/solid/qmldir
Best Answers
thank you - did work!6
