Mouse Stutter/lag when using TeamViewer
My mouse will stutter/lag when I'm running TeamViewer at foreground or background. When minimized the TeamViewer and right-click on my Desktop, the mouse cursor will stutter or lag for about 0.5 second.
  • Lisl
    Lisl Posts: 2
    Am I the only one who facing this issue ?
  • No, the past few weeks with TeamViewer12 have been awful with lagging and cursor drag / lots of spinning.  Makes it tedious at best to use.
  • IvaB
    IvaB Posts: 1
    Have you found a solution?
  • DerMaddin
    DerMaddin Posts: 1
    edited January 10
    Hey, I also always had a short freeze of the cursor when I minimized the TeamViewer session window and then hovered the mouse over a desktop element on my PC (e.g. hovering over an icon in the taskbar or over the Minimize/Maximize/Close controls of a window). Or when re-maximizing a session window and hovering the cursor over it.
    I could solve the issue by disabling Hardware Acceleration in my TeamViewer:
    (be careful when using the scroll wheel in the Settings menu as you might change some settings by mistake)
    SettingsAdvanced settingsOpen advanced settings → Scroll down to the More section → Select Disable hardware acceleration
    You need to reconnect to check if the issue is solved.
    My environment:
    TV Version: 15.49.2 (df8e23a4102)
    Windows 10 22H2 (19045.3803)
    Intel i9-13900H
    32 GB RAM
