Hi, after many years of excellent services, TV can't open anymore and quits from start. I verified my connections, particularly in Little Snitch  and VPN (both are off now), but result is same. The problems reports says (extract only):
"System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Illegal instruction: 4
Termination Reason: Namespace SIGNAL, Code 0x4
Terminating Process: exc handler [0]
Application Specific Information:
/Applications/TeamViewer.app/Contents/MacOS/TeamViewer"
So it seems that this "SIGILL" command would be responsible, but I wonder how to remove it (from the system or from the app?).
BTW, a surprising thing is that the message telling me that TV quitted unexpectedly appears in the next 3-4 seconds, and clicking on either "ignore", "notify" or "relaunch" lets it disappear but reapearing in the next few seconds (ad infinitum!). The only way to get rid of it is to send TV in the basket. I also removed TV from both folders: LaunchAgents and LaunchDeamons (looking in both HD library and ~library).
TeamViewer 13.1.1548, on Mac OS X High Sierra 10.13.3
I reinstalled it a few times (after uninstalling it completely with all its files)
Thanks for new ideas.
