I'm not sure why but I have no sound from my mac mini to my pc.
What can be done?
Hi Bear
Thanks for posting.
Unfortunately, remote sound is not possible from Mac OS. You can only hear the remote sound from a remote side if the computer you are connecting to is Windows OS.
This is currently in as a feature request for other operating systems including Mac OS but unfortunately there are technical limitations on this that make this difficult to implement.
-Scotty
Hi @Teriuwlax
It might? It would sound terrible but it might.In any case, this isn't really an intended use of that feature.
I mean, you could get a 3.5mm Aux cord, plug it into the headphone jack then back into the microphone jack and start a VoIP call if you really wanted to... but no guarantee that would work as many devices have feedback suppression.
Not to mention that would be really dodgy...
In any case, officially it is not supported by our software sorry.
Can you do voice over ip conference calls with macs? If so, shouldn't the microphone pick up the computer's sound?
No, unfortunately not.
It is not a problem of compatibility between devices, it is not possible for us to record the sound from a Mac. Remote sound is only a feature when connecting to a Windows device.
What if you are connecting mac OS to mac OS? Then can you get remote sound?
I am connected to my home PC (Win10) from work PC (Win10) and I have no sound from home PC, but I am experiencing this problem for only 5-6 weeks, in March 2018 everything was just fine.Teamviewer 13.1.3629 is on both PCs, remote sound is enabled. Is there anything else I should do to enable the sound?
Thanks a lot, GenDalf
Hi MarcusHedges,
Unfortunately, as I mentioned there are technical restrictions that make this difficult.
As far as I know, this is not on the roadmap at the moment and is not in development.Windows is the only OS that has remote sound.
Sorry for the disappointment.
Is there any update on this? In desperate need of remote access with sound for my Mac
