Remote pc(W10) crashes when Chrome is active for a while. Yes, as odd as it may sound
nmuncer
nmuncer Posts: 2
does anyone came accross the same problem and found a solution:
- I'm connected on TV 13 on windows 10
- Chrome is active on the remote desktop
- After a while, whenever I quit the session or I leave it in background and get disconnected, I no longer can access the remote pc.
- If I go and check it, has an open session (while when disconnected, it should be "closed") and computer is frozen.
It only happens when Chrome is opened on the remote desktop.
So if anyone got this type of crash and has solution, I would be pleased to hear about it.
  • cmateos
    cmateos Posts: 3
    try dissabling hardware aceleration in chrome advanced options, in configuration menu
  • nmuncer
    nmuncer Posts: 2
    thanks, will give it a try and report back if working/non working
    Have a nice weekend
