does anyone came accross the same problem and found a solution:
- I'm connected on TV 13 on windows 10
- Chrome is active on the remote desktop
- After a while, whenever I quit the session or I leave it in background and get disconnected, I no longer can access the remote pc.
- If I go and check it, has an open session (while when disconnected, it should be "closed") and computer is frozen.
It only happens when Chrome is opened on the remote desktop.
So if anyone got this type of crash and has solution, I would be pleased to hear about it.
