is there a issue with web client it wont connect to computers using chrome or IE it just shows the session is finished after attempting to connect passwords are correct can connect via android app windows app
Version: 13.0.40616
Same for me... with my smartphone (android) there is no problem, only with firefox or IE
Same for me...
The web access seems to be broken...
It won't connect via Firefox either. Same issue, it shows my computer is connected and acts like it is trying to establish a connection but then just gives me a "Session is finished" message and boots out before ever completing the connection.
