Deactivate does not work
Detected installations: 2 Remaining moves: 9
Im trying to remove a device from the web interface and I get the following error.
License activation failed. The provided ID is unknown.
    Hello dear Testuser,
    I would recommend you to log out, and to try again with an other browser.
    I hope this could help you out.
  • testuser
    testuser Posts: 2
    I just installed the license on another computer and the old ones disappeared from the UI.
    Hello testuser,
    Thank you for your reply.
    I'm glad you could solve your problem.
    Don't hesistate to re-post questions, if you encounter problems again.
    Cheers,
