Same issue.
2 -
Same here - suddenly it tells me it detected I would use it commercially. I never did that - I'm helping one of my friends once a month, or use it to check remotely if my home computer has some issue when something doesn't seem to work properly, or when I need some info I have stored only on my home computer. And that happens every blue moon.
5 -
Idem, same probleme - 10mn to reconnect Oo3
Having the same problem and now the application is threatening me with account suspension. This business detecting algorithm is getting way too aggressive. I have sent in so many tickets and they still can't seem to figure out how to unflag my account.
3 -
I have been using team viewer for years for personal use. one family member and a couple friends. I have never had any problems until now. I was able to find the "Personal Use Verification form", and submitted that after being told its really quick.
I just called in to get an idea of the turn around time and they are telling me up to 30 days?! or just pay the subscription?!
Its free for personal use or it isnt. This is used conecting from my home to another home. not to a business, not to a server, etc. I dont see how this was triggered.
I'd gladly pay 25+/year for personal use, but this just feels like a push to make ppl subscribe. There are many free options but obviously I'm here because I think TV is the best option.
Any suggestions would be appreciated to expedite the issue.
Same thing for me. I use it with family and friends and they told me that I use it on commercial use. Where did they take it???????
2 -
Same thing is happening to me. I attempted to send in the form to prove that i have only been using for personal use but upon looking in the teamviewer file there isn't a log file there so I cant submit. Is there anything that can done about this?
I'm having the same problem. My free Teamviewer account thinks I am using it commercially. I'm only using it occasionally to remote control one of my home computers to press a button quickly and then I log out. Also, I have a ministry pastor I occasionally help him with tech stuff and he is in Spain. I've never used it commecially. Please help. It locks me out after a few seconds and it's unusable.
Josh
3 -
Same for me Josh.
I'm using it for my server that's right behind me, 'cause I'm lazy
And also for a bunch of friends, if they need support. If I would get paid for that it would be nice but hey - you don't get paid by your friends for PC support. O.o
C'mon TV-Team, what's happening?
Btw. All that begun after I helped someone new yesterday for about 10 seconds, finding a program in the hidden taskbar menu of Windows.
Is there a new user limit that jumps in and activates that (We think u're using the software commercially) stuff?
Thanks in advance.EDIT: And to make it clear, I'm doing all this on a voluntary basis. No money, no company, no anything, just being a good guy.
2 -
Just happened today, so we'll have to wait and see. There are many options free and paid, but teamviewer works well and I like the interface.
Like I said, I'd pay for a personal use license, but I'm not paying anywhere close to $600 per year to use once in a while.
With all the reports of the same problem, it feels like this is a push to catch commercial use. I understand that but if it cant be addressed and corrected quickly, then its simply not worth the effort. There may be no desire to address free users, but there has to be a percentage of free users that convert for business. Why risk loosing those conversions on falsely flagged accounts?
Hi Josh,
Thank you for posting.
Please kindly refer to the article for more information about the commercial use. If you believe you are not a commercial user, you can fill the personal use verification form in the article and our engineer will check it.
Hi Psy-Virus
[deleted by moderator] I highly suggest it. Available at the [deleted by moderator]
ty, I'll check it out. I can work with anything but TV is great for the computer illiterate as well.
I should have mentioned I need something cross platform, as well. Hoping they simply address my use tho so I can stay with TV
After 15 seconds are up, it forces me to disconnect and it says to purchase a license. I thought this was free for personal use?
Guess I was wrong...
I looked up other applications that can do the same job and found real and ultra **Third Party Product**. I used to use them before I found Teamiviewer, which I liked because I didn't have to constantly try and remember the IPs of my various machines but now I am going to go back to **Third Party Product**. I have had it with Teamsucks.
There is no algorithm. They are eliminating the more active users.
@tarascon wrote:There is no algorithm. They are eliminating the more active users.
Don't know about that. I actively used TV infrequently, but got shut down. I did often leave a connection open to a second computer that didn't have its own monitor attached. I guess that could count as "use" though. Whatever. Chrome Remote Desktop. Free. Works. No **bleep**.
You bet that's use.
We are using as TeamViewer as Private (non commercial) but some how the Teamviewer have changed to Commercial and we are facing problem in it.
I request you to kindly check my log and please convert us back into Non Commercail use.Thanking you
With regards
What the **bleep**...
I had a total of 2 computers out of 5 which were detected incorrectly.
Then I sent TeamViewer a list with the IDs of all my PCs.
Results. Now comes with ALL computers the note I would use Teamviewer Commercial .... Seriously? SERIOUSLY????2 -
I have the same problem. I solved by uninstalling TeamViewer and installing it again. Good luck.
Being accused of something I never did got me so mad I switched to **Third Party Product**
3 -
Same issue here.... suddenly TW team thinks i use it for commercial purpose.... is very frustrating. And now they don't answer to private users, they send us here in the community where no one of the TW team read posts of complain about them...
3 -
Oh they read the posts. They censor any post that mentions alternatives to their software.2
Dear TeamViewer : you just ruined your society your last chance is to remove all the last commercial detections which happened this month, otherwise you'll lose thousands of people because there are a lot of alternatives which don't tell us lie to remove our free licence... And it makes you look quite unprofessional you'd better solve that issue quickly.0
I've changed to another I won't mention, TeamViewer are now in my black books and I will inform anyone who asks me that their support is rubbish, I will even go as far as to say, their support for professional is just as bad.
It's now been well over a month and a half. They sent a email saying it was fixed when it wasn't.
Which is against their modus moderandi. I read through the forum guidelines by tv and no word about mentioning other _working_ solutions3
Same here. Ticket opened on the 9th of june. Yesterday received a mail about the fix. Tested on all three machines and 2 was fixes. One still not.
Also, they "forgot" to provide the proof of commercial use (obviously as they cannot prove it as they just simply select the free users and ban them without any evidence. Friend of mine got banned on an account was not in used in the last months at all)
Amateurs.. amateurs everywhere3 -
Having the same problem and now TV13 is threatening me with account suspension.
No longer able to access home computer from work to pay bill. No access to my parent's computer to play youtube (yes, they don't know how to type Chinese on keyboard). No more home PC to home PC.
This action is quite unprofessional.
3
