Checking active channels
How to get up-to-date information about the current usage of my channels?
As we use channel groups we want to identify, which channel hasn't currently no license available. The "monthly" email (Teamviewer service hint) from teamviewer about how many connections can't be established within the past weeks doesn't help (isn't enough).
  • Esther
    Hi @Help-MF
    Did you already check the channel use under Help --> About TeamViewer --> Channel use?
    Hope that helps you.
    Best, Esther
  • DanTheMan151
    Is there no way of terminating sessions from the managment console? as much as you can see what channels are in use, the infromation is often incorrect or behind as it will dispay only 2 channels being used and yet you can't create any new connections. I asked a tech from teamviewer over the phone if this could be a custom job and pay for it and he said no :/
  • Esther
    Hi @DanTheMan151
    Let´s add it to our ideas board as a feature request for our Product Managers. May I ask you to create a new idea for this in the ideas board?
    Thanks,
    Esther
