Teamviewer when app is open Dark faded window in the way cant do anything but when i close app its g
Good day
I have a problem with teamviewer 13 when the application is open a faded dark window appears and in the window i cant click or do anything in the window but when i minimize the application all is fine again what can it be ? note this is on all workstations at the office doing the same thing.
any help would be great thanks
Yes try older version of teamviewer i reverted to teamviewer 12 and my problems were gone try to install it in a fresh way reset all settings a fresh install hope this helps.
5
Having the same issue after updating the application. Need help.
can we use old version? Will it be work?
5
