Teamviewer.exe becomes corrupted at multiple machines
We are experiencing a problem with our installations. We use TV to control multiple machines remotely. We install for unattended use. But recently we experience that the executable becomes corrupted. Even when the drives have been protected using EWF. It seems to point to TV itself. Can someone help us with this?
  • Julia
    Hi scanacar,
    Can you please give me some more information? What exactly happens and do you receive error messages? Are there any screenshots which you can provide?
    Cheers,
    Julia
  • scanacar
    There are no messages we receive. The only thing we notice is that teamviewer service will not start any more. When we look in the directory the executable files are corrupted. please see the attached imageUntitled.png
  • Julia
    Hi scanacar,
    Please uninstall TeamViewer - after that delete the following folders:
    C:\Program Files (x86)\TeamViewer      C:\Users\*username*\AppData\Roaming\TeamViewer
    Also detele the following folder in the registry:
    HKEY_LOCAL_MACHINE\SOFTWARE\\TeamViewer for 32 bit
    OR
    HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\TeamViewer for 64 bit
    After that please try to install TeamViewer again.
    Julia
  • scanacar
    Hi Julia,
    I will do this but can you please explain to me what this would help? It sounds like a general instruction like 'try to reboot your computer'. Knowing why will help us to decide if we have to do this on all machines we have in the field.
    Because EWF is enabled it should not be possible to write to the C drive. If for what ever reason the teamviewer process is trying to write to its own executable then I can imagine something goes wrong. Could this be the case?
  • scanacar
    Hi Lisa,
    I did what you asked for.
    How would we test if this resolved the issue?
    And I also see that Teamviewer logs on the c drive. Can I change this so that the logging is done on the D drive?
