hey , need your help TeamViwer 13
my computer online and i cant login with other 1 i can login with my computer to any teamviwer but no1 can login to my pc help me pls
Hi @itaymalka12,
check your options: Extras -> General -> Incoming LAN connections. What value is it reported?
Domenico Langone
Disabled0
how i can fix this
Change value to "Accept".
Go to main panel and refresh your password (icon near your password field... probably it's empty now).
Ask someone to connect to you.
Enjoy.
Regards.
Domenico Langone
no work , and i see in my friends option same like me and i can connect
but when i try connect to my pc cant ...
Could you better describe your scenario? You have two different PCs:
- connected to the same network?
- not on the same network but connected to the internet?
- Are both active, online and connected to TeamViewer?
- do they have the same version of TeamViewer, or do the caller have a more up-to-date version?Regards
Domenico Langone
I have one computer connecting to teamviewer in the new version of the software .
By the way it started only in the last few days until then everything was excellent0 -
Are you trying to connect via TeamViewer to your device, starting from the same device? Did I get it right?
Domenico Langone
I brought my friend the id to get in and there's no possibility.
up. any help ?
