16465676970275
  • jornin
    jornin Posts: 10 ✭✭
    I got that answer too. They also heavily implied to me that running Linux is something that gets you flagged too.
  • jornin
    jornin Posts: 10 ✭✭
    Having my home address and pinpointing my exact location on the planet doesn't tell TeamViewer anything about my usage. Which is what they are claiming the problem is.
    Apparently TeamViewer makes the decisions about commercial usage on things like running Plex, or having Linux as your operating system. Giving them my address isn't going to change that. Maybe they should be more honest about what qualifies as personal use, because nothing on this "community" mentions that. You have to talk to someone on the phone to get that answer.
  • DomLan
    DomLan Posts: 490 ⭐Star⭐
    Hi @jornin,
    TeamViewer already knows what use you make of their product. Every time you log in, they know your IP and the IP of the machines you connect to: obviously switching from TeamViewer servers to get back to your subnet can be expensive (connection to your media center). In this case, learning how to use SSH can completely exclude the use of TeamViewer. But this is only my opinion.
    Check the area / district where you live would help to make a further matching.
    Your credentials -> your IP -> your area -> your declaration that you use it only for personal purposes.
    In any case, if you do not want to provide this detail, you have every right to do it. However, I believe that TeamViewer's goal is to improve their discrimination system between correct use and incorrect use of the tool in free mode. In this case, complaining is of little help, but providing elements that corroborate proper use could help their technicians to fine-tune their controls.
    At the bottom it is only software, therefore perfectible.
    Just my opinion.
    Regards.
    Domenico Langone
    MCSD: App Builder
  • xbee2
    xbee2 Posts: 17
    Good luck to anyone trying to convince TeamViewer of anything different.
    They're advertising personal use as helping friends or family - that's literally what they're going by. Anything beyond "helping friends & family", is Commercial Use according to their algorithm.
    EVEN THOUGH, it is 100% non-profit, and has nothing to do with our Corporate day jobs.
  • I'm getting a headache with this commercial licence warning as I'm using it only for personal use. It disconnects after just a couple of minutes.
    I have now got to the point where TeamViewer have emailed me a link to sign a declaration form which I am happy to do BUT it has got me thinking about a point and therefore would appreciate it if someone can give me some clarification because I believe TeamViewer's website does not make it clear:
    Can I use my PC at ‘work’ to access my PC at ‘home’ for 'personal' use? TeamViewer states that you can't use it in a commercial environment, but does that mean physically or simply for commercial use? If it means the latter, then I'm certainly 'not' using it in a commercial environment. If TeamViewer means physically, then I believe they should make it clearer, so they don't waste a user's time e.g. "You may 'not' use your PC at work to connect to your mother's PC or your own home PC for personal use”. That example would be clear 'if' that is the case. It clearly states it the other way around; connecting to your PC at work from your home PC. I myself would class that as commercial use.
    Again, if you are not allowed to access non-commercial environments from your work PC then TeamViewer need to revise their statement for 'personal use'. I am using it for personal use but if the rule is only from a PC that is not 'physically' in a commercial environment then I won't sign the form, just be extremely annoyed with all the time I have invested in setting up my family’s' and friends' PCs.
    I have already told TeamViewer that I have a ‘commercial’ licence on another account but I am not going to add the aforementioned PCs to it because they are ‘personal’ so why should I include them in my ‘commercial’ account? I gave them the details of my commercial account thinking that would make them realise that I’m not trying to avoid paying them, but incredibly they have replied to state they won’t unblock my free account!
    Bizarrely too, using the free account, I don’t actually get any warning message accessing my home PC from my work PC, but I do if I access my PC upstairs or my mother’s laptop from my home PC!
    Anyway, apologies for the rant, but a little bit of understanding from TeamViewer would be nice especially as I am a paying customer!
  • xbee2
    xbee2 Posts: 17
    @Spoogle
    I spoke to them about this. While it was never clear in terms of policy, it was clear on how their algorithm works.
    In the eyes of their Algorithm - YES,  it's commercial use.
    In the eyes of their Algorithm, it's also commercial use to connect to any machine on your personal home network that you're using as a "Server". May that be File, Media, or any other PERSONAL need.
  • All I can tell you is that I do the same thing. I log in from work, as part of a Domain, from a fixed commerical IP address, to computers at my home, on an IP assigned by my local cable company / Internet provider. I sent in the logs with the form and explained this and was clearly told (~4 weeks later) that I was OK and that my account had been reset to Personal Use.
    I started getting Commercial Use pop-ups and disconnects, and refusal to even try to connect, the SAME DAY I got the email notice that my account had been reset. So, I responded directly to the email AND filled out another ticket. I got another email (much faster) saying this was OK and my account had been reset to Personal Use. Since then, so far, it has been working. I still don't feel like I can trust that it won't start up again, and of course at the most inoppurtune moment. So I am running another solution along side TV, and will continue to do so until this stops and I am convinced it is going to stay stopped, or until it starts again, in which case I am deleting TV from every computer I use it on and moving on. Time will tell.
  • jornin
    jornin Posts: 10 ✭✭
    TeamViewer's “Why do I see 'Commercial use suspected' / 'Commercial use detected' and "How exactly is "personal use" defined" pages mention nothing about running HTPC's, Plex servers, or Linux as a violation of their personal use policy.  But, a few of us on who have actually gotten to talk to someone on the phone, have heard that all three of these things could be whats causing us to get flagged as commercial use. My phone call had nothing to do with the ticket I submitted, the people on the phone refused to discuss any filed tickets.
    Today, when I got the email saying “Thank you for your request regarding being unblocked from using the free version of TeamViewer. After reviewing the information provided to us, we were unable to confirm that the submitted ID is being used privately.” they also provided the form that requested my address.
    Soooo... If TeamViewer already has vague policies that are going to claim running an HTPC or using linux is a violation of personal use, my address isn’t going to do anything to change that.
    Instead, it seems like an attempt to sell personal use subscriptions which people are being quoted at running $99-149 a year.
    Maybe someone from TeamView could clarify if they actually want my address to “make the software better.” Or, they could clarify their policies on personal use and let all of us getting tagged for this know that running an HTPC, Plex, or Linux are ineligible for free use.
    I chose to complain here because I seem to be a bit farther into the process of dealing with TeamViewer on this issue then other people. So bare minimum, I wanted to let other people know what they might be up against.
    Does anyone from TeamViewer actually answer questions here?
  • Glassdub
    Glassdub Posts: 79 ✭✭
    Resistance is futile, I guess I'm lucky ONE PC at work still works as its near impossible to use scaled on my notebook, but its very inconvenient to use that PC.
    I have no hope that my ticket is going to resolve anything by Thanksgiving if ever.
  • I've been using TV non-commercially for years and in strict accordance with their requirements.  Even stricter than yours as all of my devices on on the same non-commercial IP address, except for one that is at my other house and on a non-commercial IP address.
    This is my home, I'm a hobbiest.  Home theater, home automation, five computers, and three android devices.
    I have been told to get a license or sign a "Declaration of private use", the latter which I did and sent back.
    Can you be certain that this won't happen again? Absolutely not.  This is the third time I've been cut off of the many years.
    I would suggest that the TeamViewer accountant that has been tasked with weeding out violators use my IP to determine my address, Use google earth to confirm that it is residential, and do a google search of that address for any business, complaints, etc.  This is in no way illegal because I have given TV and various other providers the defacto right to do so.
  • xbee2
    xbee2 Posts: 17
    This whole thing needs to be re-tiered & price to actually match consumer use.
    Rather than Personal vs Commercial, $ 40+ per month.
    It should be:
    Personal - Free
    Professional - $40 - 50 USD per year
    Commercial - Commercial Prices
  • Glassdub
    Ridiculous, adding another tier resolves nothing, just because someone uses TV at work for PERSONAL reasons doesn't make it commercial, plus many home users have had this same issue no where close to a pro network.
  • Eire
    Eire Posts: 1
    I Keep getting the error commercial use suspected. I have raised this issue with Teamviewer support more than a week ago but have not received a reply. I do not usee Teamviewer for commercial use I only use it for my home computers and to troubleshoot issues for my family (not in the same country).
    Over a year ago in my previous position i was asked to assess if Teamviewer was functionally suitable for our organisation so connected to my work laptop to give it a test run. That is the only time and was/is not used for commercial reasons.
    Please support or anyone can you look into this and remove the restriction from my account as it is a real inconvienience for myself.
    Thank you.
    Peter
  •  in my case, I am not even connecting to any server.
    I am simply connecting remotely across the world betweeen Windows 10 desktops to help maintain my fathers PC so that we can use skype.
    But, teamviewer's detection algorithm is repeatedly detecting it as commerical use - this is the second time this has happened, and each time it takes many weeks to resolve. During this time, I cannot use skype to talk to my father because the remote pc has some problem or the other, and he is unable to fix it.
  • OK, I have had enough of this and it is obvious that the free version is nothing more than an unreliable trial. I have now uninstalled TV from all my computers and will be using **Third Party Product** as 17 hours a month is more than enough for my personal use.
    I'm outta here........
  • Are there any other alternatives that I don't know about out?
    **Third Party Product** looks good from feature list. I am blocked with Teamviewer anyway, and hence will install **Third Party Product** to try it out. 17hrs per month is more thanwhat I need.
  • I'm trying out **Third Party Product**.com and it looks very promising! They even have an Android app which is working well too. In many ways, **Third Party Product** seems much simpler as well. I'm trying the free version at the moment but they have  licences that start from $79 per year which seems reasonable.
    The 'only' advantage TV has as far as I can see at the moment is their Android app; they have one specifically for Samsung phones which allows me to actually take control of the phone instead of prompting (in my case) my mum with a hand icon to tap on the screen.
    Early days yet but so far so good!
  • I uninstalled TV and installed **Third Party Product** in a few minutes. It has all the same features - file transfer, multi-monitors, etc. I don't see anything lacking and so no reason to waste another minute on Teamviewer.
  • @marklein
    They blocked the mention of my alternative but your suggestion looks more promising!
    Very reasonable prices as well.
    I'll be trying that later, thank you very much indeed!
  • Just not Linux. :-(
  • GYW
    GYW Posts: 15
    I , too, have changed to this program, as suggested...and so far, it's quite good...and even affordable if you "want" to pay for it. I think TV just got too big for their pants...it's what usually happens...remember when you used to get the "works, word" program with the Windows OS and now you have to pay extra for it, or use something else? We seem to have this situation here. The thing is, if TV was really as smart as they think they are, they would develop some sort of paid version that is reasonable and just leave us alone...people hate to be called liars.
  • GYW
    GYW Posts: 15
    Apparently, this "weeding out" has been coming on for some time.  After reading many of the postings in this thread, which reflect our similar situations, I have a feeling that there will be no reasonable "fix" for personal users.  I'm sure, at this point, they aren't even reading them any more.  So it's best to look around to find something else.  I was very surprised when I found a lot more remote access programs than when I first started with TV (which was right after **Third Party Product** got rid of their free service).  So I am seriously trying out a few...and taking into consideration that the majority of the people I assist in my family are truely at the stage of "how do I turn the computer on"...lol.  Initially, it made me angry too, but after all is said and done, the only thing it is forcing us to do is search for a better program and help build THAT company until they decide it's time to get rid of the free service.
  • What the **bleep** is going on with this? I have V13 installed with a corporate licence installed on 2 machines, one I use for remote support for friends, family and clients the other is setup so that my step father can do his work from home for his clinic.. why are we all of a sudden getting this error?
  • xbee2
    xbee2 Posts: 17
    Speaking to the TV person that I did, we're not being called "liars", she mentioned a lot of people that use TeamViewer in more of an advanced way that their algorithm will detect & flag as Commercial use.
    She instead offered suggested solutions such as a discounted Business Plan. I heard her say as much as 50% off. Unfortunately, I still can't support that. Because:
    1. I'd be enabling what's happening
    2. I feel a personal use "Pro" version should cost no more than $50 USD a year.
    It's Management & the Developers that control the algorithm. So no matter who we can speak with at TV, they have no such power to change it. Despite what's actually written as official Personal vs Commercial use policy.
  • jornin
    jornin Posts: 10 ✭✭
    That's such garbage. My highly technical use of TV is logging into my HTPC from my laptop instead of pulling the ottomon up to where the PC lives in the living room. "OMG COMMERCIAL USE DECTECTED - user reclassified part of his movie collection into folders labeled with the directors name!"
  •  Después de muchos años de usar en forma personal y privada el TV, me apareció esta suspensión por"estar usándolo en forma comercial" lo cuál no es cierto.
    Qué debo hacer para recuperar el programa en modo "free" ?
    Carlos Castellano
  • Well did you maybe log into your HTPC from your laptop to jump past a COMMERCIAL, or maybe during a COMMERCIAL? Maybe that triggers COMMERCIAL USE!! :smileytongue:
  • For me, the point is, regardless of their algorithms, they make it clear on their website that they don't want people to pay for personal use and market themselves with a charitable and generous attitude, and so I spent time and effort putting their product on my friends' and family's devices only to be denied access.
    When I ask them what's happening , they say they believe I'm using it for commercial use and I should pay for licence but to convince them otherwise I have to go through this lengthy process of trying to prove to them that I'm not using it for commercial use where they reply at their leisure.
    We are at a crossroads, either they call me a liar because of their blasted algorithms or lift the ban. There is no trust or goodwill with them, and I really don't like their attitude and feel they are deceivers.
    I feel conned out of my time and effort and would have much rather have paid a 'reasonable' price for a personal use licence either from them or someone else.
    I now have the hassle and inconvenience of some how installing alternative software on everyones' devices.
    Ironically I have a commercial licence for clients but don't see why I have put my personal ones on that account too because they are for PERSONAL USE!
  • xbee2
    xbee2 Posts: 17
    The whole inconvenience of setting up a new remote solution on all family, friends, and personal remote devices is what's really bumming me out.
    I've spent years getting people accustomed to teamviewer, and now I need to force a change. That's probably what TV's Management is banking on, that we'll pay for the easy way out.
    But even accomplishing all that work, is still better than paying $40+ USD per month. And of course the best part would be not giving into basically what I would consider a hostage situation and a middle finger to its users.
  • Teamviewer team just reset my license back to Free - my appreciation and thanks to the support team.
    Thanks to many in the forum for your wonderful suggestions. I am planning to install two 3rd party alternatives suggested on this forum. The two are intended to be my backup incase Teamviewer licensing check again miscategorizes me as a commerical user and blocks my access.
    Since Teamviewer has worked before for a while and since I know it is difficult to deal with fraud in freemium models, I am still going to give one more try to teamviewer. If that bug in licensing code blocks me again, it is unfortunate, but my only option is to delete team viewer permanently.
    I hope the teamviewer engineering team prioritizes fixing the licensing check to be not overly agressive or atleast design a permanent licensing override so that the same customer does not get blocked many times for same issue.
    As we all know,  Freemium model companies that have been wildly sucessful have NOT frustrated a large section of their free customers - my best wishes to Teamviewer team to get this licensing issue under control.
