getting autorization authorizationCode
I'm looking for the authorzation code for my app!
after following all the process given in the documentation example for managing user with python , I'm getting this error:
you cannot grant access to this app, because your account does not have the permissions.....
before getting The AUthorizaion code!
Any help?
  • EspyM
    EspyM Posts: 2
    Ok! Thanks for the clarification!
    so my next question is how to get thoses privileges?
    I've just create my acount yesterday i doesn't have any license ! I'm testing if it can fit to my project
  • DomLan
    DomLan Posts: 490 ⭐Star⭐
    Hi EspyM,
    try to use Management Console Web of TeamViewer. You can reach it in these alternative ways:
    a) TeamViewer -> Connection -> Open Management Console;
    b) Teamviewer computer and Contact list -> box with 3 lines -> Open Managemen Console;
    c) login at https://www.teamviewer.com
    There is a manual detailing how to use it: https://www.teamviewer.com/en/support/documents/
    I hope this helps
    Domenico Langone
    MCSD: App Builder
  • DomLan
    Domenico Langone
    MCSD: App Builder
