Are there parameters to start TeamViewer?
I have a requirement where TeamViewer.exe needs to be started from command line using the -i parameter. My question is to know if there is any provision to pass the user-id of the teamviewer account in command line.
  • Esther
    Hi @Ginu_Gopinath
    I hope this article will help you:
    All the best, Esther
  • FabrizioC
    Hi there!
    I'm configuring a TeamViewer package to install silently.
    Can I use the same parameters for the TeamViewer_Host_Setup.exe?
    Many thanks in advance,
    Fabrizio
    @Esther wrote:
    Hi @Ginu_Gopinath
  • AlbertoC71
    Hi, I tryed to insert this command into my windows applications (Vb.Net):
    Dim processo As Process
    processo = New Process
    processo.StartInfo.FileName = "C:\Program Files (x86)\TeamViewer\TeamViewer.exe -i xxxxxxxxx --Password xxxx"
    but unfortunately it doesn't work.
    On my pc I have a "free" teamvier13 license installed.
    Mayby, I have to install the paid version ?
  • AlbertoC71
    Hy, If I use this command  processo.StartInfo.FileName = "C:\Program Files (x86)\TeamViewer\TeamViewer.exe"     without    -i xxxxxxxxx --Password xxxx"      it works correctly !!
  • AlbertoC71
  • DomLan
    DomLan Posts: 490 ⭐Star⭐
    Hey @AlbertoC71,
    use System.Diagnostic.ProcessStartInfo with Argument parameter set.
    Check also with and without using UseShellExecute.
    Domenico Langone
    MCSD: App Builder
