Can I change the ports for Teamviewers in Windows
I facing a problem, after Teamviewer installed, one application doesn't works properly, the support from the applications say this is due to Teamviewer using the port, and this application won't change port. So I have to think another way to change the ports for Teamviewer.
  • Maurice
    Maurice Posts: 10 Staff member 🤠
    TeamViewer normally uses port 5939 for communication between processes and port 5938 if you have enabled LAN connections in the options. The first port can be changed by adding a registry value under HKLM\SOFTWARE\WOW6432Node\TeamViewer named "IPC_Port_Service" (type: DWORD) and set it to a different port. The second port cannot be changed, but you can disable it in the options (General -> Incoming LAN connections -> deactivated).
    Maurice
    Software Developer
  • eddieluk
    eddieluk Posts: 2 ✭✭
    hi Maurice, Tks for quick reply, I will test is on my laptop.
  • Gos
    Gos Posts: 1
    Is it possible to specify which port you want to connect to though?
    The use case would be for port-NAT access in from
    external users, who are dependant on using IP-addresses.
    (Remote Agent 123.123.123.123) -> (Customer-FW)222.222.222.222:5938 -> [Customer FW Port NAT] -> Server 1 10.10.10.10:5938
    (Remote Agent 123.123.123.123) -> (Customer-FW)222.222.222.222:6938 -> [Customer FW Port NAT] -> Server 2 10.20.20.20:5938
    (Remote Agent 123.123.123.123) -> (Customer-FW)222.222.222.222:7938 -> [Customer FW Port NAT] -> Server 3 10.30.30.30:5938
