teamviewer down?
cant connect to the teamviewer server anymore.
2 hours ago everything was fine, and now i get 'check your internet connection', but my connection is fine.  i login with email and password on teamviewer.
its my home computer, and i dont use a proxy.
tried a reinstall (worked on my work laptop yesterday), but still nothing.
  • JoshP
    JoshP Posts: 484 Senior Moderator
    Hello @Ruud-G,
    We were not aware of any issues. You can always check the status of our services here.
    If you are still unable to connect, please restart the device you are in front of and try again.
    Josh P.
    Senior Community Moderator
