From a Windows 10 PC any remote host only shows a black screen
erniemjt
I'm running version 14.2.2558 with a premium license.
Hello @erniemjt,
Indeed, this problem has been reported by some users in the past. Therefore, we have created two articles about this topic. Please have a look at them, you might find the solution to your issue:
- Why do I only see a black screen after connection establishment?
- The screen cannot be captured - Fast user switching
French Community Moderator0 -
Thank you for the suggestions @JeanK! Unfortunately, neither link was helpful in the situation.
I can use my Macbook to connect to Server1 with no problem. When I use my Windows 10 laptop, black screen. From my Windows 10 desktop, it works fine. It is only on my Windows laptop which is what I use 99% of the time for my connections.
