Team Viewer 14 not starting on reboot Windows 7
I have spent hours researching this. I think I have done all of the suggestions I have found to make TeamViewer start on reboot on Windows 7 including uninstalling and re-installing. It will not start on reboot. I must be missing the magic setting or checkmark somehow. Can anyone give me direction to make this work every time? Thanks!
Find more posts tagged with
@Plus wrote:Latest version didn't fix this problem, TeamViewer_Service.exe take long time to start with Windows, that causes the LAN and wifi hangs 10 seconds, affect on Win 7 to 8.1 all version
Well, it "hangs" until I manually start it. IMO, that's not a "hang", that's simply a failure to start. Doesn't matter if it's 10 minutes or 10 hours.
I have the same issue and, so far, I've not seen one single reply that works, and this has been going on for at least 4 version releases. Using TV14 14.2.8352, upated Apr 15, 2019. Windows 7 Pro 64, updated as of Apr 16, 2019. I have uninstalled and reinstalled TV, with reboots, several times, including older versions back to at least 10, and the issue still remains. If I don't remember to manually start TV after a reboot, it simply will NOT start. YES, I do have the option to start with windows checked. Does ANYONE have even a workaround, let alone a real solution?
Not as of TV 14.2.8352... :-(
