Hi,Yesterday i´ve installed a brand new Windows 10 Build 1703 with a Teamviewer Host 12 for remote control. I can use Teamviewer as long as any user is signed in. After a reboot or signing out i can´t connect again.
Please help!
Karsten
Automatic logon to Windows is a workaround for this (yet unsolved huge!) problem: https://www.cnet.com/how-to/automatically-log-in-to-your-windows-10-pc/Still if you happen to log out (and disconnect form teamviewer), you won't be able to reconnect later.
this dont´t work for me. It´s not an upgrade.
There is a similar case, but not a solution until yet. :
https://community.teamviewer.com/t5/TeamViewer-12/Windows-10-does-not-look-to-start-service-until-logon/m-p/6120#U6120
https://community.teamviewer.com/t5/forums/replypage/board-id/TeamViewer_12/message-id/2327
You may want to read this post. A similar problem was resolved by rolling back the Windows version.
https://community.teamviewer.com/t5/TeamViewer-11/User-permission/td-p/219
Here is something else to try.
Options > Advanced > (Show Advanced Options) > Full access control when a partner is conecting to the Windows logon screen.
Thx for your reply, but this didn´t help.
