Outlook add-in causes crash
Outllok disables teamviever add-in on startup due to it causing a crash. I can activate it but sure enough when o go to schedule a meeting it freezes Outlook.
I can start Teamviewer meeting directly but i can schedule them and send the inviet through outlook evein if it's initiatled in the team viewer app.
I have tried to unisntall teamviewer and re install but the behaviour is persistent.
All was working fine until I changed my Harddrive. I cloned the old one to the new one without any other issues so this could just be a coincidence.
any isdeas on how to solve this?
same Problem here
Same... reinstalled TV but it crashes and never loads the meeting into Outlook.
Same issue here. Has anyone heard back from Teamviwer regaarding this issue?
It is a known bug and our developers has worked on it.
We apologize for any inconvenience caused. As soon as I get more information I will keep you updated in the community.Best regards,
YuriCommunity Moderator/ コミュニティモデレーター0 -
Has anyone else had any luck resolving this yet or heard back from Teamviewer yet? Updating to the latest 14.2.8352 has not resolved this for our users.
Any update, Teamviewer team???
Same here, still broken with Outlook 2019 16.0.10344.20008 64-bit & TeamViewer 14.2.8352
Same problem here.
Hi All,
Thank you for your posts
We are planning to fix this known bug with version 14.3.
You can try the insider builds now however please be aware that insider builds may have other bugs.Thank you for your patience and understanding.
Hope this information will be helpful.Best regards,
Pls can you inform this group when version 14.3 will be avaiable and what insider builds will also solve the issue.
Bob
Hello, pls can you inform me as to when 14.3 will be avaiable?
