Connection Problem: Mac Mojave 10.14.5 - 2019-Jun-5
Hi, I cannot start teamvier on my Macbook for recent days.
Could you tell me how to fix it?
Thanks!
Os: Mac Mojave 10.14.5
Teamviewer version: 14.2.8352
Date: 5-Jun-2019
Screen Shot 2019-06-05 at 10.08.19.pngScreen Shot 2019-06-05 at 10.12.33.png
  • Yuri_T
    Hi @duongtx90 ,
    It could be multiple reasons to be considered in your case. However from your screenshot, it did not go through TeamViewer server.
    Therefore as the frist step, could you please read this article and check if the Internet environment is ok?
    Please check your connection
    This is the article about  MacOS Mojave.
    Hope this will be helpful.
    Yuri
  • duongtx90
    duongtx90 Posts: 3
    Hi Yuri,
    I used to use it ok last week.
    The internet connection is ok, I replied from same device
    My macbook is currently turned off firewall and grant access for Accessibility option.
    Before I press Connect button the status was green - "Ready to connect"
    Here is the log I get from console:
    [Please do not post the logfile as per the community guideline.]
  • Yuri_T
    Hi @duongtx90 ,
    Thank you for your reply.
    I am glad that it works now!
    If there is any other questions, please feel free to post again.
    Yuri
