Adding customized QuickSupport for older (Teamviewer 10) license
rontovi
rontovi Posts: 3 ✭✭
I have a Teamviewer 10 Premium license and I need to create a new customized-QuickSupport for my new project.
I can do it in the panel actually but the problem is, the QuickSupport (TeamViewerQS.exe) comes with the latest Teamviewer version. And when it runs on a client computer, it directly gives error about licensing, starting with something like:
"You're using the new Teamviewer - newest and fastest generation.
(bla bla bla...)"
Licensing error on Teamviewer QuickSupportLicensing error on Teamviewer QuickSupport
I do not want or need the newest version, I'm happy with my Teamviewer 10 so I want to create a QuickSupport for version 10. How can I do that ?
Thanks.
    Hello @rontovi
    In order to download your customized QuickSupport in version 10, you need to click on Download previous version during the loading page of your customized QuickSupport.
    Note: You will find this button on the left bottom corner of your page.
    This should download the QuickSupport in version 10 of your TeamViewer license.
  • rontovi
    rontovi Posts: 3 ✭✭
    Hello again, thank you for your reply.
    In download page my for QuickSupport, there is a link on the left bottom sayin "Previous version" and when I click at it, it probably downloads the version 13 because it's link is going to:
    https://get.teamviewer.com/v13/<quicksupport_id>
    I have manually changed the URL and tried https://get.teamviewer.com/v10/<quicksupport_id>
    This is how it worked, for any further support request for others...
    Thank you.
  • J-M
    J-M Posts: 1
    What about version 6? My pro license is for v6.x only
    Hello @J-M,
    Try then maybe with https://get.teamviewer.com/v6/YourQS-ID...
    I wish you a great day.
