Blank screen or Fuzzy screen
inovateam
inovateam Posts: 3 ✭✭
I've described my issue (with printscreen image and report) in the #2813949 ticket.
Since the update to the new version (12) I can'g give any kind of support to some customers because I cannot see the host screen (it's blank or fuzzy).
It's important. Please anser me.
Best Regards,
José Ferreira - InovaTeam
Best Answers
  • mLipok
    mLipok Posts: 781 ⭐Star⭐
    To solve this problem I use "Optimize for quality" or "Optimize for speed" button.
    This change current screen to proper quality.
    mLipok , AutoIt MVP
  • G-Rega
    G-Rega Posts: 1
    Not a good solution. The picture is a little bit better, but still at least a half of screen is not OK.
  • mLipok
    With one case I had the same problem (my solution wont work), but after closing connection and opening again + using my solution this was succesfully fixed.
    To other members who confirm alredy by pressing "Me too": please confirm if my solution works or not in your case.
    mLipok , AutoIt MVP
  • inovateam
    Thanks for the answer but I'm afraid your suggestion it's not enough to solve the problem.
    With the v11 we don't have any problem...
    It's possible to downgrade?...
