Logging of remote maching connection status.
Does Teamviewer store a permanent log of notifications from machines logging on and off?
If so where might this be found?
We are trying to track the reliability of the service connecting one of our servers.
Any suggestions/help will e appreciated
  • Ying_Q
    Ying_Q Posts: 2,598 Moderator
    Hi @SmartH
    TeamViewer does has logfile that you may find the path to find log files. However that TeamViewer log files are for debug purpose and only TeamViewer Technical Supporters analyse the data records.
    Alternatively that your may try the function of connection reports which allows TeamViewer to record the information of users incoming and outgoing connections, and these reports are available on TeamViewer Management Console.
    Hope it helps.
    Community Moderator/中文社区管理员
