Blocking a user from TeamViewer on my computer
I have a guest user on my computer and I do not want them to have access to TeamViewer.  How do I do that?
  • Ying_Q
    Ying_Q Posts: 2,598 Moderator
    Hi @graptemys
    You may set up a Black and Whiltelist for restricting the accessibility of your TeamViewer.
    Hope it is helpful.
    Community Moderator/中文社区管理员
  • graptemys
    graptemys Posts: 2
    Hello, Ying_Q
    This actually is not the problem I have.  I have a home desktop computer that I have TeamViewer installed on so I can access my files remotely.  I have a guest user profile set up on this computer, and I have blocked access to my files on the hard drive, but the guest user still has access to TeamViewer.  How do I block access to TeamViewer for this guest user? The procedure you referred to only accepts email addresses from remote users.
