Connection to remote machine disconnects frequently
We have Teamviewer v12.0.1394.37 installed on mac mini as a remote machine.
Our macbook also use the same version of Teamviewer to connect to remote machine, but the connection interupts many times per 5 -10 minutes or even less. After being disconnected, the account on remote machine is logged out completely.
I've tried deleting com.teamviewer.teamviewer.preferences.plist file on the HOST machine from the ~/library/preferences folder and then reboot but the problem is still persist.
Please help if you have any idea.
    Hello @taitranevz,
    What you could try is to disable UDP during the connection to this particular device.
    To do so, please open your TeamViewer client and go to:
    Extras → Options → Advanced → Advanced network settings
    and untick Use UDP.
    If it does not help, please activate the UDP feature back again and open a ticket via: Open a ticket now!
    Our support will be happy to help you out!
  • taitranevz
    Thanks for your support, JeanK. I disabled UDP per your suggestion but the issue is still persist (screen-shot here:https://prnt.sc/o6prdz). Please advise if you have any other idea.
