Android team viewer is not logging in using mobile data
Hi Sakkthi,
Can you please try it again to see if it works now? In which country are you located?
Julia
Country India.
Using airtel 4G and Jio 4G not connecting in both.
Sign in failed check your internet connection and try again.
I can log into my account and connect computers using Wifi.
I am in Australia, using Telstra network, having the same issue.
when using 4G it doesn't work, but switch to 3G it works...
