Recover a recorded session after a crash
Hi everyone,
I was recording a presentation I did for my students as I do frequently, but this time the computer crashed, so the Save popup was never shown....
Is there any temporary file from where I can recover the recording ?
Thanks !
  • PabloTISPabloTIS Posts: 4
    I found the file on C:\Users\pablo\AppData\Local\Temp\TeamViewer
    it has 450Mb but TeamViewer can't read the file :smileysad:
  • yanivbenarityanivbenarit Posts: 8 ✭✭
    I have the same problem.
    i dont' know why it happened at all , because the connection seemed to be fine, but saving the viedo got crashed sometimes...
    basically it's happening once a day, when i record video about 20 times. So every 20 records, one record video failed.
    hope to get any solution.
  • HoussamHoussam Posts: 2
    i have the same problem also;
    does any anyone know how to recover the tvs file found into temp folder ?
    Do you find a solution for this file in temp ?
  • Pretty sad that this has not been solved. Crash handling should be solved problem.
