Copy and Paste does not work
Hi
I have this issue on MAC and can't find a mac installer version of 14.1
if the "type clipboard" option would allow us to use the local clipboard to enter the password, this would solve the issue we encounter when using very long, complex passwords instead of the randomly generated ones from teamviewer itself.
In my opinion this is a must have option, as without out it the security when getting remote access to computers whose users are not very computer savy is compromised.
thanks,
Chuck Haatvedt
2 -
We'd like to use this option as well though we've changed from **Third Party Product** Central to Teamviewer Corporate. Within Teamviewer we had options like copy & paste passwords at logon as well as hard reset clients that were not responding properly. Also the function to shadow user sessions on terminal servers was a mainly used feature within **Third Party Product** whereas Teamviewer is no capable. Can you please tell us if these or similar options will get into Teamviewer as new features?
1
