Teamviewer GPG key is blocking _all_ updates on entire system in "GNOME Software" app.
@rolandg Thanks for the reply.
$ hostnamectl Static hostname: ckr-1Pretty hostname: CKR-1Icon name: computer-desktopChassis: desktopMachine ID: 5dcae607682f4bcda4b0f76aab639ddcBoot ID: ddc6361109e34e7e9add0afd948e371aOperating System: Fedora 30 (Workstation Edition)CPE OS Name: cpe:/o:fedoraproject:fedora:30Kernel: Linux 5.2.13-200.fc30.x86_64Architecture: x86-64
$ rpm -q gpg-pubkey --qf '%{NAME}-%{VERSION}-%{RELEASE}\t%{SUMMARY}\n' | grep TeamViewer<no-results>
$ rpm -q gpg-pubkey --qf '%{NAME}-%{VERSION}-%{RELEASE}\t%{SUMMARY}\n'gpg-pubkey-cfc659b9-5b6eac67 gpg(Fedora (30) <fedora-30-primary@fedoraproject.org>)gpg-pubkey-c0aeda6e-5ad45327 gpg(RPM Fusion free repository for Fedora (30) <rpmfusion-buildsys@lists.rpmfusion.org>)gpg-pubkey-1d14a795-5ad4532e gpg(RPM Fusion nonfree repository for Fedora (30) <rpmfusion-buildsys@lists.rpmfusion.org>)gpg-pubkey-7fac5991-4615767f gpg(Google, Inc. Linux Package Signing Key <linux-packages-keymaster@google.com>)gpg-pubkey-d38b4796-570c8cd3 gpg(Google Inc. (Linux Packages Signing Authority) <linux-packages-keymaster@google.com>)
Turns-out that Fedora's "GNOME Software" can't add/update GPG keys through the GUI. I've opened a bug-report at Fedora for this.
SOLUTION:
$ sudo dnf upgrade -b --refresh && sudo dnf autoremove && sudo dnf needs-restarting && sudo dnf check all [sudo] password for chris: Fedora 30 openh264 (From Cisco) - x86_64 845 B/s | 542 B 00:00 Fedora Modular 30 - x86_64 65 kB/s | 18 kB 00:00 Fedora Modular 30 - x86_64 - Updates 54 kB/s | 17 kB 00:00 Fedora 30 - x86_64 - Updates 57 kB/s | 18 kB 00:00 Fedora 30 - x86_64 - Updates 1.7 MB/s | 24 MB 00:14 Fedora 30 - x86_64 89 kB/s | 18 kB 00:00 google-chrome 19 kB/s | 1.3 kB 00:00 google-chrome 26 kB/s | 4.0 kB 00:00 RPM Fusion for Fedora 30 - Free tainted 3.4 kB/s | 3.0 kB 00:00 RPM Fusion for Fedora 30 - Free - Updates 3.8 kB/s | 3.0 kB 00:00 RPM Fusion for Fedora 30 - Free 4.0 kB/s | 3.2 kB 00:00 RPM Fusion for Fedora 30 - Nonfree tainted 4.8 kB/s | 3.0 kB 00:00 RPM Fusion for Fedora 30 - Nonfree - Updates 4.2 kB/s | 3.0 kB 00:00 RPM Fusion for Fedora 30 - Nonfree 4.2 kB/s | 3.2 kB 00:00 TeamViewer - x86_64 10 kB/s | 2.5 kB 00:00 Dependencies resolved.=============================================================================================================================================================================================================================================== Package Architecture Version Repository Size===============================================================================================================================================================================================================================================Upgrading: teamviewer x86_64 14.6.995-0 teamviewer 13 MTransaction Summary===============================================================================================================================================================================================================================================Upgrade 1 PackageTotal download size: 13 MIs this ok [y/N]: yDownloading Packages:teamviewer_14.6.995.x86_64.rpm 4.1 MB/s | 13 MB 00:03 -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Total 4.1 MB/s | 13 MB 00:03 warning: /var/cache/dnf/teamviewer-9f08dda5da172238/packages/teamviewer_14.6.995.x86_64.rpm: Header V4 RSA/SHA1 Signature, key ID 0c1289c0: NOKEYTeamViewer - x86_64 5.1 kB/s | 3.1 kB 00:00 Importing GPG key 0x0C1289C0: Userid : "TeamViewer GmbH (TeamViewer Linux 2017) <support@teamviewer.com>" Fingerprint: 8CAE 012E BFAC 38B1 7A93 7CD8 C5E2 2450 0C12 89C0 From : http://linux.teamviewer.com/pubkey/TeamViewer2017.ascIs this ok [y/N]: yKey imported successfullyRunning transaction checkTransaction check succeeded.Running transaction testTransaction test succeeded.Running transaction Running scriptlet: teamviewer-14.6.995-0.x86_64 1/1 Preparing : 1/1 Upgrading : teamviewer-14.6.995-0.x86_64 1/2 Running scriptlet: teamviewer-14.6.995-0.x86_64 1/2 Removed /etc/systemd/system/multi-user.target.wants/teamviewerd.service.gtk-update-icon-cache: Cache file created successfully. Running scriptlet: teamviewer-14.5.5819-0.x86_64 2/2 Cleanup : teamviewer-14.5.5819-0.x86_64 2/2 Running scriptlet: teamviewer-14.5.5819-0.x86_64 2/2 Verifying : teamviewer-14.6.995-0.x86_64 1/2 Verifying : teamviewer-14.5.5819-0.x86_64 2/2 Upgraded: teamviewer-14.6.995-0.x86_64 Complete!
The suggested fix did not work for me, but I was able to use the workaround (disabling the repo in the Software hamburger) to allow the OS and other app updates to proceed.
I've had teamviewer installed for some time, but only recently updated Fedora from 29 to 30. Perhaps this issue came with the Fedora upgrade?
hi,
for me on an openSUSE box the TV yum repo works fine.
which distribution are you using ?
is the TeamViewer GPG key imported into the rpm db ?plz check with: rpm -q gpg-pubkey --qf '%{NAME}-%{VERSION}-%{RELEASE}\t%{SUMMARY}\n' | grep TeamViewer
brRoland
Disable the Teamviewer repo in the GNOME Software app hamburger menu at top-right till they fix this.
Have you heard?! On October 21, we’re hosting TeamViewer Rise—and we want to see you there! The digital event dedicated to IT experts. Join us to hear industry leaders as they share demos, roadmaps, and real-world strategies for delivering better IT. Take part in our first annual event for Proven, ready-to-deploy…
